LMS 3.1 Campus Manager 5.1.0 - ANIServer process trouble
Answered Question
No matter what i do i just cant seem to get the ANIServer process to run. I have even restored the campus manager DB.
Please please help. thank in advance
Correct Answer by Joe Clarke about 8 years 7 months ago
The ANIServer.properties is completely corrupt. Copy NMSROOT/campus/etc/cwsi/ANIServer.properties.orig to ANIServer.properties. Then modify the file, and change the DEVICESROOT line to read:
DEVICESROOT=NMSROOT\\campus\\lib\\classpath
Where NMSROOT is the path into which LMS was installed (e.g. C:\\PROGRA~1\\CSCOpx). Also, change the AniName line to:
AniName=ANIServer6.0-boe-ciscoworks2
After that, ANIServer should start.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 12/16/2008 - 08:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the ANIServer.log and the ani.log.
Joe Clarke Tue, 12/16/2008 - 08:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It appears you have a few problems. First, check the permissions on d:\PROGRA~1\CSCOpx\campus\etc\cwsi\ANIServer.properties. Make sure the casusers group has full control to this file, and all parent directories. Second, the ANI database appears to be down. Please post the output of the pdshow command.
The casuser has full rights to the file and all of the D: in fact
D:\Program Files\CSCOpx\campus>pdshow ANIServer
Process= ANIServer
State = Failed to run
Pid = 0
RC = -1
Signo = 1073741823
Start = N/A
Stop = 12/16/2008 4:25:57 PM
Core = Not applicable
Info = Application failed or was registered incorrectly.
Joe Clarke Tue, 12/16/2008 - 08:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I wanted to see the entire pdshow output. Additionally, please post NMSROOT/campus/etc/cwsi/ANIServer.properties.
Correct Answer
Joe Clarke Tue, 12/16/2008 - 08:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
