Configure IPS on Router
Dear All,
I am novice in the security, excuse me if my question is very basic.
I want to configure IPS on Cisco 2821 router. I do not have any server for storing the logs.
Kindly let me know:
Is it possible to configure IPS on a router 2821?
Is it going to increase the CPU utilisation?
Kindly let me have the command/link to configure IPS on the router.
Thnx,
Ashish
rsakthiv Tue, 12/16/2008 - 23:48
Hi Ashish,
You can configure IPS on Cisco 2821.Just load it with an image that supports security features.
Here's a good Q&A guide that may help you.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6634/prod_qas0900aecd806fc530.html
For configuration, you can refer to http://www.cisco.com/en/US/products/ps6634/products_configuration_example09186a008097dbe8.shtml
The CPU util depends on the number of signatures enabled and the amount/type of traffic the router is handling.
HTH.
--Raj
