Warning message
Location can't find clients
Dec 16th, 2008
In this Location is Reachable state and synchronizes seamlessly with the controllers. But do not get any client. The error that appears is as follows:
192.168.20.6: Internal error in location server. Error Message:Server response: [Solid JDBC 04.50.0133]SOLID SQL Error 13: illegal column name 'AESMOBILESTATIMLOCATION.CHANGEDON'
Does anyone could help me? What could be happening?
Thank you.
wesleyterry Tue, 12/16/2008 - 09:46
  • Bronze, 100 points or more
What version of the location appliance are you running?
What version of WCS?
It looks to me like the Location appliance is either referencing a column that does not exist in the SOLID database (on WCS?) or it is maybe recieving data with that column name and doesn't have anywhere to put it.
I would think this is either a serious database corruption/bug or the location appliance and WCS are at incompatible versions....?
slandeira Tue, 12/30/2008 - 08:56
The versions are:
Location 4.0.38.0
WCS 4.1.91.0
Controllers 4.1.185.0
In the matrix don't show these incompatible versions.
¿Database corruption? ¿server error??
Scott Fella Tue, 12/30/2008 - 09:02
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
That is not compatible... 4.0.38.0 is too high of a firmware for 4.1.185:
http://www.cisco.com/en/US/docs/wireless/location/2700/release/notes/larn4038.html#wp39483
If you keep your wlc & wcs at that firmware, then you need to load 3.0.42 on the LB.
http://www.cisco.com/en/US/docs/wireless/location/2700/release/notes/larn3042.html#wp998995
Any version 3.1 or higher will require WCS to be at least 4.2.x code.
slandeira Fri, 01/09/2009 - 05:01
I tried to change the version of 4.0.38 to 3.0.42 but I can not make it run.
The error I get is:
[[email protected] locserver]# /etc/init.d/locserverd start
Starting locserverd: [ OK ]
[[email protected] locserver]# /etc/init.d/locserverd status
Getting the status locserverd: com.aes.client.AesClientException: Request to server failed, reason: java.security.PrivilegedActionException: com.sun.xml.messaging.saaj.SOAPExceptionImpl: Message send failed
at com.aes.client.AesClientAdminImpl.getServerInfo(Unknown Source)
at com.aes.server.cli.CmdGetServerInfo.run(Unknown Source)
at com.aes.server.cli.CmdGetServerInfo.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at com.zerog.lax.LAX.launch(DashoA8113)
at com.zerog.lax.LAX.main(DashoA8113)
I attached a file with the upgrade process.
¡¡PLEASE HELP!
jamespiljay Thu, 01/15/2009 - 17:07
If you have had success in uninstalling the incompatible code and now have the proper code installed, try the following, the db is most likely corrupt:
/etc/init.d/locserverd stop
cd /opt/locserver/db/linux
mv server-eng.db ./server-eng.db.old
Dave Anthony David Wed, 02/25/2009 - 02:13
I had same error to..
[[email protected] linux]# /etc/init.d/locserverd status
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
slandeira Wed, 02/25/2009 - 03:05
In my case the problem fix with the upgrade version of the Controllers. Make sure that no problems of incompatibility between the versions of WCS, WLC and location.
