Disabling Spanning-Tree of a port by port basis
Answered Question
Dec 16th, 2008
Hi There,
Is it possible to completely disable spanning-tree on a trunk port. I have a situation were a Sun server will be connected to a trunk port and will be tagging packets with various vlan ids. I have been told that the port must have spanning-tree disabled (yes I know its madness).
I had previously thought that it was only possible to turn vlan off on a vlan by vlan basis on a switch.
Is it possible to turn spanning-tree off on an individual port basis.
Correct Answer by Jon Marshall about 8 years 3 months ago
Jim
You can effectively turn off STP for a port by using the "spanning-tree bpdufilter enable" command under the interface -
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_s2.html#wp1014574
Do you know why you have to disable it. If it is an issue with the NIC taking 45 seconds to begin forwarding you could look to use "spanning-tree portfast trunk" which allows the trunk port to begin forwarding immmediately but still runs STP - it's like normal portfast but for trunk links. It should never really be used on switch to switch links but it is fine for servers with trunk links.
Jon
Overall Rating: 0 (1 ratings)
Correct Answer
Jon Marshall Tue, 12/16/2008 - 08:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jim
Jon
tobin_jim@hotma... Wed, 12/17/2008 - 02:38
Jon,
Thanks for the information. I actually already have the ports on "spanning-tree portfast trunk" but I've been told that the manufacturer guideline is for spanning-tree to be completely disabled.
I think for this case though that the portfast trunk command will be sufficient.
Thanks again.
