ping & tracerout through firewall
Dec 16th, 2008
I am trying to get a few workstations to ping and traceroute to the Internet via an ASA5520. I have a permit ip any any for all incoming traffic hitting the inside interface and still unable to ping\traceroute the Internet.
any idea?
ronshuster Tue, 12/16/2008 - 08:23
Our internet access works perfectly ok from a NAT & PAT & ACL stand point... only thing is that we cannot ping & traceroute to the Internet.
I have a permit ip any any on all traffic incoming the INSIDE interface. Is that sufficient or do I need to apply the following as well:
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any time-exceeded
ronshuster Tue, 12/16/2008 - 08:46
I just ran a packet capture, results:
RESULTS - The packet is dropped
Info : (rpf violated) Reverse-path verify failed
I tried to remove the following but still unable to ping:
ip verify reverse-path interface Outside
ip verify reverse-path interface Inside
nefkensp Tue, 12/16/2008 - 13:08
If you're using the asa, you also need to configure the ICMP inspection using the icmp permit command set;
e.g.
icmp permit any inside
icmp permit echo-reply outside
icmp permit unreachable outside
icmp permit traceroute outside
P-J Nefkens
ajagadee Tue, 12/16/2008 - 14:23
The above lines need to be applied on the outside interface.
access-group 101 in interface outside
OR
The other option is to enable inspection:
For example:
policy-map global_policy
class inspection_default
inspect icmp
Please refer the below URL for details:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
Arul
*Pls rate if it helps*
