Private-VLAN SVI routing
Dec 16th, 2008
I am trying to configure private vlans on a few 3750 switches where the primary VLAN is a layer-3 SVI on a 3750. I can get secondary community VLANs talking within each community, but nothing can talk to the primary VLAN default gateway (the SVI). I can only mapping the secondary VLANs to the interface:
interface vlan 50
ip address 10.6.35.254 255.255.240.0
private-vlan mapping 51-52
...there is no option to set it as a promiscuous interface...
Installing a router and connecting to a 3750 via a promiscuous port (mapping all the secondary VLANs), works fine.
Is this a known issue with layer-3 interfaces on switches? Is there a solution?
Many thanks
Phil
Giuseppe Larosa Tue, 12/16/2008 - 10:24
Hello Phil,
the commands you have issued are correct but something could be missing.
1) when creating an SVI you need to add a
no shut
2) check the vlan 50 status with
sh int vlan50
it has to be up/up
normal SVI interfaces have the autostate concept : they are up/up only if there is at least a L2 port either access or trunk in STP forwarding for the Vlan.
here should be enough to do the no sh
Hope to help
Giuseppe
phil_carter Wed, 12/17/2008 - 00:59
Layer-2 VLANs all configured correctly (50 primary with 51 and 52 secondary community VLANs). Layer-3 SVI is up/up and enabled. Trunk ports exist and there is something in each VLAN.
Community VLANs can talk within each VLAN (ie VLAN51 can talk to other ports in VLAN51 and 52 to 52), but nothing can ping the primary VLAN 50 SVI.
config used:
interface vlan50
no shut
interface f0/1
description VLAN51 host 10.6.35.40
switchport mode private-vlan host
switchport private-vlan host-association 50 51
speed 100
duplex full
spanning-tree portfast
no shut
interface f0/2
description VLAN51 host 10.6.35.100
speed 100
duplex full
no shut
10.6.35.40 can ping 10.6.35.100 and vice-versa, but nothing can ping the default gateway 10.6.35.254.
If I connect a router to the 3750 which has a layer-3 interface and config the 3750 switchport as a promiscuous port it works OK:
Router:
interface f0/0
description facing switch
speed 100
duplex full
no shut
Switch:
interface f1/0/24
description connection to router
switchport mode private-vlan promiscuous
switchport private-vlan mapping 50 51-52
speed 100
duplex full
no shut
Do private-vlans not work with SVI's?? If so, how do you configure them to work?
Phil
viyuan700 Wed, 12/17/2008 - 01:29
can you check the output of this command
show interfaces private-vlan mapping
phil_carter Wed, 12/17/2008 - 01:56
outputs below:
Switch#sh vlan private-vlan
Primary Secondary Type Ports
50 51 community Fa1/0/1, Fa1/0/2
50 52 isolated
Switch#sh int private-vlan mapping
Interface Secondary VLAN Type
vlan50 51 community
vlan50 52 isolated
Phil
Giuseppe Larosa Wed, 12/17/2008 - 13:08
Hello Phil,
excuse me for the basic question
have you defined the primary vlan at layer2 ?
conf t
vlan 50
private-vlan primary
private-vlan association 51-52
this is needed as it is needed the command under the SVI interface vlan 50
Hope to help
Giuseppe
phil_carter Thu, 12/18/2008 - 01:04
Yes - all VLANs fine at Layer-2 (see previous outputs provided).... it works fine when configuring a promiscuous port to a router, just not when trying to speak via an SVI (with secondary VLANs mapped to it)...
Phil
