VPN backup with HSRP
Dec 16th, 2008
Hi all
I have an issue with one branch office who connects to the central via VPN. This branch have two routers with HSRP and tracking for backup purposes and both have the same VPN configuration to the Cisco ASA central office. When outage occurs in the branch, HSRP works fine and the VPN between secondary router and central ASA wakes up and all runs OK. When the main internet access of the branch office comes up again, the HSRP returns the management to the primary router and the secondary VPN dies, the problem is that for some reason, the central ASA keeps the route to the secondary router. This causes that packets from remote site come to central office by the primary VPN but try to return for the secondary one (died due to preemtion of remote site HSRP). I have tried with IKE timmings with no success
Any suggestions?
Thank you
Miquel
srue Tue, 12/16/2008 - 10:13
  • Blue, 1500 points or more
are you sourcing your router/hsrp vpn's from a loopback?
cisco24x7 Tue, 12/16/2008 - 11:25
  • Silver, 250 points or more
You need to use Reverse route injection (RRI)
and "crypto map xxx redundancy". You should be
peering the ASA with the HSRP ip address.
Just keep in mind that this is NOT stateful
IPSec failover.
this is a classic CCIE security problem
