LMS - Inventory collections problem
Dec 16th, 2008
hi all
I am unable to do Data inventory. (all jobs failed)
I did a test on 1 device; i removed it from the RME devices, and from the DFM devices list.
discovered it again and the discovery ended successfully.
I then added it back to the the DFM and RME devices lists and did a job INVENTORY COLLECTION for this device only (credentials were also added), and left it for more then 12 hours and the job is still in the running status, what can i do about this issue
Please advise
Joe Clarke Tue, 12/16/2008 - 09:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the IC_Server.log as well as the name and IP address of this device.
Joe Clarke Tue, 12/16/2008 - 10:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
NMSROOT\log where NMSROOT is the path into which CiscoWorks was installed.
stephenwa Wed, 12/17/2008 - 10:18
I am running LMS 3.1 for Windows. I am having a similar problem and have been working with the TAC to resolve it. I went through a similar exercise, verifying credentials, deleting and adding devices etc. All with no success. It seems that I can not collect device inventory on a 3750 or 2950 switches. IC gets stuck on these type of devices and then can't proceed with inventory collection for other devices. The error handling in IC needs a fix in order to overcome this issue. Working with the TAC Engineer we ran a series of diagnostics and batch files in order to determine the problem and possible fixes. I have spent a considerable amount of time in Webex sessions, gathering logs, debug output and sending it to TAC who then forwards it on to the developers in India. I am expecting to hear back from them today with next steps. Stay tuned...
jorjes1984 Wed, 12/17/2008 - 13:35
Thx man for you input
I will be waiting for your updates.....
Joe Clarke Wed, 12/17/2008 - 13:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
That would be a mistake. Your inventory problems may be completely different than this other user's. You should post the IC_Server.log so your problem can be identified.
jorjes1984 Wed, 12/17/2008 - 14:03
yah i will for sure,
I just couldn't pass to the client today...
I will pass ASAP and post themm....
Joe Clarke Wed, 12/17/2008 - 22:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Your problem is upgrade related. The database was not properly upgraded with the correct schema definitions. We've seen this a few times before, and it points to an improper installation on Windows.
The best solution is to fix the installation problems, uninstall, then reinstall LMS from scratch.
First, run the uninstall program, and remove LMS. Then reboot. Then login as a local Administrator on the server's console. Set the values of the TEMP and TMP environment variables to something short like C:\WINDOWS\TEMP. then, disable anti-virus software. Then do the reinstallation.
When the reinstallation is complete, reboot. Then apply any patches and updates you may have had applied previously. Again, do these as a local Administrator on the console with anti-virus software disabled. After all of that, the RME database should be good, and inventory (and everything else) should work.
jorjes1984 Thu, 12/18/2008 - 08:11
HI
concerning the UNINSTALL PART.
When i insert the LMS 3.0 CD, do i get the uninstall option?
Joe Clarke Thu, 12/18/2008 - 10:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The uninstall program can be found under Start > All Porgrams > CiscoWorks.
