Which IOS On A 3640 Router For Home Lab
Dec 16th, 2008
I have a 3640 for my home lab, and need to upgrade the IOS. Which one is the lowest one that will work. I need the one labeled ENTERPRISE/SNASW PLUS or will the one that just says IP work for a home lab?
tperrier Wed, 12/17/2008 - 00:20
It only depends on what you want to do with the lab! IP has less features than other variants, but if you don't use these features, they'll obviously be of no use to you...
Also keep in mind more advanced versions need more RAM and flash, so you may have to upgrade the hardware first.
