Query on TIMEZONE CONFIGURATION
Dec 16th, 2008
I have Small query on timezone..
My network falls under CST timmings. I have configured the following commnand for the same.
clock timezone CST -6 // Is it right //
How to configure the daylight saving for the same..
sateesh
Richard Burts Tue, 12/16/2008 - 11:54
sateesh
Yes your configuration of the timezone looks correcct. To configure dayligt savings use this:
clock summer-time CDT recurring
Rick
sateeshk10 Tue, 12/16/2008 - 12:41
HI,
Thanks for ur reply..
What z the meaning of CDT..(Is it WOrd or i need give same thing)
After clock summer-time ? its showing word ..what z the word..
sateesh
Richard Burts Tue, 12/16/2008 - 13:17
Sateesh
The configuration command is looking for some word (some variable name) which it will use as a literal when it displays the time.
Since you had used CST (Central Standard Time) for the timezone I thought it reasonable to use CDT (Central Daylight Time) for summertime. You do not have to use that and may use any word that you choose for this.
Rick
