Cisco Works LMS and HP NNM
Answered Question
Dec 16th, 2008
Will LMS 3.1 integrate with NNM starter edition 7.5x for Windows or do I need the Advanced Edition ? No real information on HPs web site about the differences bar the node limitation of 250 which is fine for my customer.
Also can they both run on the same (dedicated) PC these days. It's years since I played with NNM or CiscoWorks.
Correct Answer by Joe Clarke about 8 years 2 months ago
The integration was not tested with the Starter Edition, but it should work if the only difference is the allowed node count. NNM 7.5 and LMS 3.1 can be installed on the same server provided you have enough resources for each suite.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 12/16/2008 - 12:28
Patrick Colbeck Tue, 12/16/2008 - 12:50
Thanks. I just got of the phone with HP and they say that the license restriction is the only real difference. In fact there is a license option to upgrade it to Advanced. So we should be fine.
Thanks for the speedy answer.
