Regarding usage of passive-interface default
Answered Question
Dec 16th, 2008
Dear friends,
I am running OSPF on Ten Gig interfaces between Core and Distribution switches.
I want Distribution 1 and Distribution 2 switch (redundant switches) to not be OSPF adjancent.
I wanted to know that if i apply the following commands, will it be ok.
router ospf 10
no passive-interface t2/3
no passive-interface t3/3
T2/3 and T3/3 are Core-1 and Core-2 connecting interfaces. Will applying the command passive-interface default override the previous 2 "no passive-interface commands" or no??
Just wanted to double check this part.
Thanks a lot
Gautam
Correct Answer by Jon Marshall about 8 years 6 months ago
Gautam
Yes this should be fine. You can verify the interface settings once you have added this config -
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t2/feature/guide/defint.html#wp10202
Edit - apologies i completely misread the question. Rick is correct - the passive-interface default will not override the previous no passive-interface commands. It will just make all other interfaces than t2/3 & t3/3 passive.
Jon
Correct Answer by Giuseppe Larosa about 8 years 6 months ago
hello Gautam,
you still need to add the network area commands for the interfaces of interest.
2) if the default becomes passive-interface you need no passive-interface for interfaces where you want OSPF hellos to be sent out so the more specific command applies:
no passive for interfaces t2/3 and t3/3 passive for all the other ones whose IP subnets match a network area command
Hope to help
Giuseppe
Correct Answer by Richard Burts about 8 years 6 months ago
Gautam
No the passive interface default will not override the the no passive-interface commands. It makes the default behavior to become passive. But any interface configured with no passive-interface will become active.
Rick
Overall Rating: 5 (3 ratings)
Correct Answer
Richard Burts Tue, 12/16/2008 - 12:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Gautam
Rick
Correct Answer
Giuseppe Larosa Tue, 12/16/2008 - 12:42
  • Hall of Fame,
    Founding Member
hello Gautam,
Hope to help
Giuseppe
Correct Answer
Jon Marshall Tue, 12/16/2008 - 12:43
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Gautam
Jon
Chalermchai D H... Mon, 05/07/2012 - 10:45
  • Cisco Employee,
This not true.  If you add passive interface default, it will wipe out other 'no passive-interface ' commands.. at least in 12.2(33)SXI5 and 12.4(15)T8.
r2#show run | be router ospf
router ospf 1
log-adjacency-changes
no passive-interface Ethernet0/0
no passive-interface Ethernet1/0
network 2.2.2.2 0.0.0.0 area 0
network 10.1.12.0 0.0.0.255 area 0
network 10.1.23.0 0.0.0.255 area 0
r2#
r2#conf
r2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
r2(config)#router ospf 1
r2(config-router)#pass
r2(config-router)#passive-interface default
r2(config-router)#end
r2#show run | be
00:01:46: %SYS-5-CONFIG_I: Configured from console by console
router ospf 1
r2#sh ver
Cisco IOS Software, Solaris Software (UNIX-P-M), Version 12.2(33)SXI5, DEVELOPMENT TEST SOFTWARE
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 03-Feb-11 08:47 by prod_rel_team
r3#show run | section router ospf
router ospf 1
network 3.3.3.3 0.0.0.0 area 0
network 10.1.34.0 0.0.0.255 area 0
r3#
r3#conf t
r3(config)#router ospf 1
r3(config-router)#pass
r3(config-router)#passive-interface default
r3(config-router)#do show run | sec router ospf
router ospf 1
r3(config-router)#do sh ver
Cisco IOS Software, Solaris Software (UNIX-P-M), Version 12.4(15)T8, DEVELOPMENT TEST SOFTWARE
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 03-Dec-08 14:46 by prod_rel_team
Joseph W. Doherty Mon, 05/07/2012 - 17:51
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Just wanted to also confirm Chalermchai's post, i.e. sequence of these commands can matter.
On some version of 6500 IOS, I've found OSPF's passive-interface or no passive-interface only take if they are contrary to the current default setting.
e.g.
router ospf 1
or
router ospf 1
no passive-interface default
are okay but
router ospf 1
!already no passive-interface default
or
router ospf 1
!already passive-interface default
were not okay.
Richard Burts Tue, 05/08/2012 - 06:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
This is certainly an interesting and unexpected behavior. As I think about it I would certainly agree with Joseph's point that sometimes the order of commands can affect how things work. And in a sense it is logical that if you have an existing configuration and you change the default behavior of the routing protocol (from default not passive to default passive) that it might reset the existing config to conform to the new default behavior.
I wonder if this represents a change in behavior introduced at some release? I thought that I remembered having configured a routing protocol, added the passive-interface default and not having impacted the existing config.
Rick
