HSRP ip routing tracking
Dec 16th, 2008
I have 3 routers- see diagram. R2 is active hsrp with R1. what i am trying to do is track ip routing eth0/2 and eth0/3 on R2. if both interfaces loose EIGRP routes from R3, them decrement hsrp priority to 20. based on the configuration below, it looks like the tracking ip-routing only monitor the line-protocol for the interfaces not the routing reachability. can someone perhaps advise how to go about using hsrp based on ip routing (eigrp) on R2.
track 1 interface Ethernet0/2 ip routing
track 2 interface Ethernet0/3 ip routing
track 100 list boolean and
object 1
object 2
interface Ethernet0/0
no ip address
interface Ethernet0/1
ip address
standby 1 ip
standby 1 timers 1 3
standby 1 priority 115
standby 1 preempt delay minimum 60
standby 1 authentication secret
standby 1 name LAB
standby 1 track 100 decrement 20
R2#sh ip route eigrp
D [90/409600] via, 00:00:15, Ethernet0/3
[90/409600] via, 00:00:15, Ethernet0/2
D [90/307200] via, 00:00:15, Ethernet0/1
[90/307200] via, 00:00:15, Ethernet0/3
[90/307200] via, 00:00:15, Ethernet0/2
R2#sh standby brief
P indicates configured to preempt.
Interface Grp Prio P State Active Standby Virtual IP
Et0/1 1 115 P Active local
Giuseppe Larosa Tue, 12/16/2008 - 13:35
Hello Francisco,
see the following link the ip route option
track object-number ip route ip-address/prefix-length {metric threshold | reachability}
metric threshold I think is AD, reachability if it can be accessed
so if this works define track for some routes of interest that are learned from EIGRP
Hope to help
