DS3
Answered Question
Dec 16th, 2008
Hi All
What's the lowest cost router that will support a DS3, no need to channelize, all data.
Alex
Correct Answer by ajagadee about 8 years 2 months ago
Alex,
The NM-1T3/E3 on a 2800 ISR will be lowest cost. But, that is without any services running on the router. If you are planning to run any services on the router along with line rate DS3, I would look at the 3845. This chassis gives you Full-rate T3/E3 with concurrent services. Example, QoS, ACL, Security Features, etc. Please refer the below URL for details.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps4909/product_data_sheet09186a008010fba2.html
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Joseph W. Doherty Tue, 12/16/2008 - 16:23
Support it in the sense of providing an interface or support it in the sense being able to support full DS3 bandwidth?
alex goshtaei Tue, 12/16/2008 - 16:25
actually both, we need to install DS3 card and provide DS3 bandwidth to the WAN connection.
Thanks for your reply
Alex
Joseph W. Doherty Tue, 12/16/2008 - 17:29
As Arul notes, Cisco would normally recommend at 3845. However, the 3825 seems to usually work well with a full DS3 too. From performance specs, a 2851 might come close, but haven't seen one in operation with a full DS3.
I have seen a full DS3 on as small as 2811, but it maxed when you tried to go much above 15 Mbps (duplex).
Correct Answer
ajagadee Tue, 12/16/2008 - 17:00
Alex,
Arul
alex goshtaei Tue, 12/16/2008 - 17:23
this is fantastic, I didn't know there is NM module for T3.
thanks again for great answer.
Alex
