Appending Digits to Dialed Numbers
vgioia5090
I have been trying to get my ccme to append 1772(1+area code)on my 7 digit calls but have been unable to get it to work. I ahve included my config, can anyone give me an example of how to make that work?
voice translation-rule 1
rule 1 /9911/ /911/
rule 2 /9411/ /411/
voice translation-rule 2
rule 1 /9772+/ /1772/
voice translation-rule 3
rule 1 /9+/ /1772/
voice translation-rule 4
rule 1 /91+/ /1/
voice translation-rule 5
rule 1 /1777250XXXX/ /101/
voice translation-rule 7
rule 1 /1../ /1777250XXXX/
voice translation-profile CALLCENTRIC_Incoming
translate called 1
voice translation-profile Incoming
translate called 5
voice translation-profile Local10
translate calling 7
translate called 2
voice translation-profile Local7
translate calling 7
translate called 3
voice translation-profile LongDistance
translate calling 7
translate called 4
voice translation-profile Services
translate calling 7
translate called 1
dial-peer voice 1 voip
translation-profile outgoing services
destination-pattern [49]11
session protocol sipv2
session target dns:callcentric.com
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 2 voip
translation-profile outgoing Local10
destination-pattern [2-9]......
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3 voip
translation-profile outgoing Local7
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 4 voip
translation-profile outgoing LongDistance
destination-pattern 1[2-9]..[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
It's probably because dial peer 2 and 3 are overlapping.
In these cases you really should do something like 'debug voip dialpeer' and make sure you're hitting the right dial peer, along with test voice translation
Delete dial peer 2, and I think this will work.
7 Replies 7
rule 1 /9+/ /1772/
If you're trying to add 1772 to a 7 digit number that has a 9 before it, it would look like this:
rule 1 /^9\(.......\)$/ /1722\1/
hi, i tried this and it didnt make any difference, did i miss something. would you mind giving an example config? at this time i dont dial a 9 and dont want to. my provider wants the 1772 in front of the number or the calls wont go through. any ideas?
This is supposed to be an example.
If you don't have a 9, it would look like this:
rule 1 /^\(.......\)$/ /1722\1/
i added this and tried it, but its still not working. i did a debug ccsip calls and it shows the only 7 digits being dialed. any ideas, maybe something else is overiding this entry?
awesome thank you! that worked!
Marwan ALshawi
do the following
voice-translation rule 1
rule 1 /\(^9.*\)/ /1772\1/
voice translation-profile p1
trnslate called 1
translation-profile outgoing p1
this will work
also with pots u can use prefix digits
by the way the above will translate any called number start with 9
u can cahne this part based on what number u wanna match
/\(^9.*\)/
for example
/\(^[2-9].+\)/ /1772\1/
this will match any number start with any number between 2 to 9 and prepend 1772 to it
good luck
hope this helps
