CM 6.X LDAP Authentication with Microsoft AD
Dec 16th, 2008
Hi everyone,
Can you offer guidance on the following scenario? I have read the SRND and Config guide for LDAP integration. My question is regarding the setup of the User Search Base. Here is my setup...1 Domain with 1 main OU which is subdivided into several smaller OU's. For Example:
Domain = cisco (for some strange reason, there's no ending to the domain....will this be an issue?)
Main OU = TEAMS
Sub OU = A
Sub-Sub OU = 1
First Users
Sub-Sub OU = 2
Second Usrs
Sub OU = B
Sub-Sub OU = 1
Third Users
Sub OU = C
Sub-Sub OU = 1
Fourth Users
In order to integrate CM with AD, will I need to create multiple ldap directories searches and syncs, or can I specify the Main OU of TEAMS and the sub OU users will also be pulled in?
vhilario Tue, 12/16/2008 - 23:04
You can specify the main OU in this case TEAMS and the Sub OU's will be pulled in to the CUCM server.
Under LDAP User Search base (let's say your domain is cisco.com)
So you should have
ou=TEAMS,dc=cisco,dc=com
See this link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/5x/50drctry_ps556_TSD_Products_Implementation_Design_Guide_Chapter.html#wp1057076
If this helps pls rate
Viri
