service clid_authen_collect anable in CME 7.0
Dec 16th, 2008
I have enable PIN option as is shown but sometimes after dialing the phone number the prompts which ask the user and PIN is not listen and the call goes through.
how can I check the reason the user and PIN is not asked?
param uid-len 3
param pin-len 3
username 369 password 7 091F1850
dial-peer voice 202 pots
corlist outgoing Cell
description Cellular Calls
destination-pattern 9044..........
port 0/2/0:1
prefix 044
dial-peer voice 1202 voip
description Cellular Calls con PIN
session target ipv4:
incoming called-number 9044..........
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
