WAAS PREPOSITIONING DELAY 17 HOURS
Dec 17th, 2008
I am using WAAS inline infrastructure ( 1 Central Manager and 2 Application 612 ) Inline method with SERVER prepostioning . When I try to schedule the push of proposition in the GUI TAB > CONFIGURE PREPOSITIONING > PREPOSITION STATUS the conter say me that is in Porgress and is take 17 hour to make a prepostion of 10 Mb file !
Is it normal ? Or I do something wrong ?
nchidamb Fri, 12/19/2008 - 10:45
What is the WAN link b/w and latency you have on that link? What type of file is it (pre-compressed or encrypted or plain text etc)? Just for troubleshooting purpose have you tried transfering that file over that WAN link using regular file transfer using FTP or Windows drag & drop (CIFS based). If so, how long does it take?
Btw, just curious, what version of code you are running on the WAEs and Central manager?
abelleli71 Sun, 12/21/2008 - 23:49
Hello
the answer : Code 4.1 of the WAAS. There is no transfer .. I mean its only preposition and If i bring va FTP the transfer takes less than a minute but the proposition take hours . Wan link is clear ATM 8 Mb/s
nchidamb Mon, 01/12/2009 - 05:06
Did you verify that under 'Schedule' tab you have chosen 'Now'?
