voip dialing problem
mathieu.ploton
Here is my configuration :
Cisco 2611XM connected to my PABX through E1/T1 interfaces and two remote agencies with INTIP cards on their PABX.
When i dial from my local PABX to site B, it's working fine. When Site A try to dial Site B, it's not working.
It's weird because in the log, I see the same numbers dialing :
Here it's a call from Site A to Site B, using a tempo :
Dec 13 01:29:27 10.55.1.3 53570: Dec 13 01:28:35.104: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 4942BA09 8E3DD4F4 240080 9F048807, SetupTime 01:28:05.264 PARIS Sat Dec 13 2008, PeerAddress 8996111, PeerSubAddress , DisconnectCause 66 , DisconnectText recovery on timer expiry (102), ConnectTime 01:28:35.104 PARIS Sat
Here, it's a call from site A to site B using a number of digits
Dec 13 2008, DisconnectTime 01:28:35.104 PARIS Sat Dec 13 2008, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Dec 13 01:29:47 10.55.1.3 53571: Dec 13 01:28:55.065: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 4942BA3B ABEBBE08 210080 9F048807, SetupTime 01:28:55.045 PARIS Sat Dec 13 2008, PeerAddress 8996111, PeerSubAddress , DisconnectCause 3 , DisconnectText no route to destination (3), ConnectTime 01:28:55.055 PARIS Sat Dec 13 2008, DisconnectTime 01:28:55.055 PARIS Sat Dec 13 2008, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
When i try the same, in my local PABX? i see normal call clearing and the Peer Address in my log is the good one (8996111).
My dialpeer :
dial-peer voice 1 pots
description POTS
destination-pattern 669....
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
translate-outgoing calling 488
no digit-strip
direct-inward-dial
port 1/0:15
forward-digits 5
dial-peer voice 11 voip
description SITE A
preference 1
destination-pattern 888T
progress_ind setup enable 1
translate-outgoing called 888
session target ipv4:10.10.10.5
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 13 voip
description SITE B
destination-pattern 899T
translate-outgoing called 899
session target ipv4:10.20.10.5
no vad
aghaznavi
Level 5
Level 5
This message provides call history detail. Call history detail output is used in simple accounting. The ASCII comma-delimited output can be stored using the syslogd command and passed on to other billing or processing software on a server.
Recommended Action: No action is required.
For further information click this link.
CDR Logging Configuration with Syslog Servers and Cisco IOS Gateways [Gateway Protocols]
