Changing EMP IP address
Answered Question
Dec 17th, 2008
Hi, I need to change both MCU and EMP IP address. I lost the serial cable and I was wondering how can I change EMP's IP address?
Thanks in advance
Correct Answer by ecarabias about 8 years 6 months ago
Connect via telnet. If you don't have a prompt press Ctrl+C. For seeing the configuration menu execute the command modifyTargetDevice (case sensitive). When you exit the menu the EMP reboots.
Hope it helps!
Overall Rating: 5 (2 ratings)
Correct Answer
ecarabias Wed, 12/17/2008 - 01:21
Hope it helps!
