Warning message
User in a windows group - mapping to acs group appears not be working
Dec 17th, 2008
  • Bronze, 100 points or more
I have a user in a windows group, this windows group is mapped to an ACS group but when the user logs in it appears as default group in ACS.
Any suggestion?
rowl1004 Wed, 12/17/2008 - 09:03
Hello, I recently implemented this very thing, actually integrated it with Authentication Proxy. Here are some settings to check:
1. External User Databases - Database Configuration - Windows Database - Configure
Make sure your domain is listed on moved to the Domain List section
2. External User Databases - Database Group Mappings - Windows Database - - Add Manual Mapping
Make sure you have the right AD group mapped to the internal ACS group, you can even set users* if you want to include all users.
3. External User Databses - Unknown User Policy
Check the "Check the following external user databases" radio dial and move Windows Database to Selected Databases
Check “The database in which the user profile is held” radio dial in the Configure Enable Password Behaviour section
Hope that helps!
