When reloading router it goes in RMON mode
Dec 17th, 2008
Hi All,When we reload the Cisco 7606 router it always goes to the Rommon Mode. Can anyone tell me whats is the reason behind this.
Any suggestion will be appriciated.
ryel.dsouza Wed, 12/17/2008 - 03:35
check the configuration registry ???
it should be 0x2102.
do "sh ver" and go to the bottom and check it!!
Jon Marshall Wed, 12/17/2008 - 05:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
When in rommon do you just type boot or do you have to tell it where the image is ?
Once thing to try is to set confreg in rommon mode.
Jon
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
double posted in error
Nicholas Matthews Wed, 12/17/2008 - 19:30
  • Red, 2250 points or more
I seem to remember that some platforms would boot to rommon if there was not a boot statement in IOS. I can't recall if the 7600 was one of these devices.
If you don't have 'boot system flash ' make sure you have that there.
inayathulla1 Thu, 12/18/2008 - 02:00
Hi All,
From this perspective i see there is issue with the conf register due to which the router is going to Rommon mode after the reload of the device.
I request you to please check the following:-
Complete these steps:
In global configuration mode, issue the config-register 0x2102 command, and set the configuration register to 0x2102 for both the RP and the SP.
6500_IOS# config t
Enter configuration commands, one per line. End with CNTL/Z.
6500_IOS(config)# config-register 0x2102
6500_IOS(config)# end
To verify the configuration register value at the next reload, issue the show bootvar command.
6500_IOS# show bootvar
BOOT variable = slot0:c6sup12-ps-mz.121-13.E14,1
CONFIG_FILE variable =
BOOTLDR variable =
To verify that the configuration register on the SP also changed, issue the remote command switch show bootvar command.
6500_IOS# remote command switch show bootvar
6500_IOS-sp#
BOOTLDR variable =
Configuration register is 0x2 (will be 0x2102 at next reload)
Reload the switch for the new SP configuration register setting to take effect.
6500_IOS# reload
Note: You can issue the copy running-config startup-config command at this point to save the configuration. However, this step is not necessary because the configuration register setting is not part of the startup or running configuration.
I hope this should solve your issue.As i am 100 % confident on this.
Plz rate if this help.
Inayath.
