Backup From console
Dec 17th, 2008
Hi ,,
I want yo take a backup "running config" from a router using a console. Can I?
Jon Marshall Wed, 12/17/2008 - 05:17
I'm assuming you mean when you are consoled into the router. If so you could just cut & paste from the terminal windown to notepad or with a lot of terminal programs there is an option to capture the text, see this link for more details -
glen.grant Wed, 12/17/2008 - 10:14
If you use something like Tera Term just turn on the log function and on the device do a term length 0 and then do a sh runn and that will write the whole config into the file, then you just name and close the log file.
amarmn1975 Wed, 12/17/2008 - 19:39
Thannks to all of you, but I ment that If I can do the command
#copy running-config or xmodem.
like tftp.
