6513 power supply disabled
Dec 17th, 2008
I have a problem with PS2 being disabled in a 6513. The system reports that PS2 has a different capacity from PS1. But I know the two power supplies are the same model, and replacing PS2 does not solve the problem. Has anyone come across anything like this before?
From show system:
PS1-Type PS2-Type
WS-CAC-4000W-INT WS-CAC-4000W-INT
Modem Baud Backplane-Traffic Peak Peak-Time
disable 9600 1% 13% Sat Dec 13 2008, 23:17:24
PS1 Capacity: 3830.40 Watts (91.20 Amps @42V)
PS2 Capacity: 3795.12 Watts (90.36 Amps @42V
PS Configuration : PS1 and PS2 in Redundant Configuration. PS2 disabled.
From show ver:
WS-C6513 Software, Version NmpSW: 7.3(2)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Aug 1 2002, 17:57:20
System Bootstrap Version: 7.1(1)
Hardware Version: 1.0 Model: WS-C6513 Serial #: TBM06109172
PS1 Module: WS-CAC-4000W-INT Serial #: SON05200008
PS2 Module: WS-CAC-4000W-INT Serial #: SNI1220BM54
Harry
satish_zanjurne Wed, 12/17/2008 - 05:28
Hi Harry,
If possible, can you try both these power supplies in different chassis ?
See the result on different chassis.
HTH...rate if helpful..
h.cox Fri, 12/19/2008 - 02:01
Thanks for the response. I have suggested a swap of PS2s between chassis, so we'll see what happens.
It will be interesting to know if the capacity reported for a PSU comes directly from ther PSU, or is it a massaged figure from the chassis.
Harry
aceschia Tue, 06/09/2009 - 08:00
Harry
i'm facing the same issue in these days(below there is the output from my customer chassis).
Looking at official documentation, our chassis behave as expected.
With power redundancy enabled, if you have unequal power supplies
the lower-wattage one is disabled by software:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa8.shtml
What I think is happening is just a (silly) weakness in the software: in our cases there is
a very little difference in the supplied watts from the two PSs.
Anyway this difference is enough to force the OS to disable the lower-wattage PS.
I think that differences may normally arise due to different manufacturers, different hardware
revisions and so on.
A common point in our cases are the S/Ns , I have the same combination.
SONxxxxx (PS1) provides 3830.40 , SNIyyyyy (PS2) provides 3795.12
To me, It looks like we're pointing to a time frame large enough to introduce a little
technical differences between the two. (SON sounds newer than SNI)
A solution may be to turn off redundancy with both power being combined.
Anyway I think it will be well worth to open a Service Request to inform TAC that this
behaviour is causing issues to customers and a small difference should be tolerated.
From this perspective, I will update you if possible.
Kind regards
Andrea Ceschia
Exctracted from the show tech
PS1 Module: WS-CAC-4000W-INT Serial #: SON05160236
PS2 Module: WS-CAC-4000W-INT Serial #: SNI1050BM1Y
PS1-Type PS2-Type
disable 9600 0% 6% Mon Jan 26 2009, 15:34:24
PS2 Capacity: 3795.12 Watts (90.36 Amps @42V)
