12-17-2008 05:06 AM - edited 03-06-2019 03:01 AM
Imagine I have 3 networks: Lan1, Lan2, and WAN for example.
I want Lan1 clients to access Lan2 natted (ie overlapping Lan2 gw).
Up to here it seems to be an easy task. I do config ip nat inside and ip nat outside in Lan1 and Lan2 networks. I do configure ip nat static source list with an access-list which allows only Lan1 to Lan2 traffic.
What do I need to do if I want Lan1 hosts to accces Wan network without being natted? Without further configuration I do not have communication between Lan1 and Wan unless I add ip nat outside to Wan interface, and I change acl for allowing this traffic as well.
Is it possible this scenario?
Thanks in advance,
Jorge
12-17-2008 05:12 AM
Jorge
Could you post config of router.
Jon
12-17-2008 07:36 AM
Sure:
hostname 6501
no aaa new-model
ip subnet-zero
no ip domain-lookup
no mls flow ip
no mls acl tcam share-global
mls ip slb purge global
mls ip multicast flow-stat-timer 9
mls cef error action freeze
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
redundancy
mode sso
main-cpu
auto-sync running-config
system flowcontrol bus auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
no crypto ipsec nat-transparency udp-encaps
interface GigabitEthernet4/21
switchport
switchport access vlan1
no ip address
interface GigabitEthernet4/22
switchport
switchport access vlan2
no ip address
interface GigabitEthernet4/23
switchport
switchport access vlan3
no ip address
interface Vlan1
description LAN1
ip nat inside
interface Vlan2
description LAN2
ip address 192.168.2.1 255.255.255.0
ip nat outside
interface Vlan3
description WAN
ip address 192.168.3.1 255.255.255.0
ip nat static source list 101 interface vlan2 overlap
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
ip default-gateway 192.168.3.2
ip classless
end
12-17-2008 07:47 AM
Hey!!
I found answer by myself. I think I need to use route-maps instead of access list!!
I ll try and let you know.
12-17-2008 09:14 AM
Hi again, couldnt make it work :-(
Packets from vlan 1 to vlan 2 natted, but no communication between vlan 1 and vlan 3.
Thing is that icmp request from vlan 1 reach unnatted vlan3, but icmp replays from vlan3 do not come back.
Any idea?
This is what I did:
hostname 6501
no aaa new-model
ip subnet-zero
no ip domain-lookup
no mls flow ip
redundancy
mode sso
main-cpu
switchport
no ip address
switchport
no ip address
switchport
no ip address
interface Vlan1
description LAN1
ip nat inside
interface Vlan2
description LAN2
ip nat outside
interface Vlan3
description WAN
ip nat inside source route-map Nat_only_vlan1_2 interface vlan 6 overload
access-list 101 deny ip 192.168.1.0 0.0.0.255 any
route-map Nat_only_vlan1_2 permit 1
match ip address 101
ip classless
end
Thanks in advance
12-17-2008 09:35 AM
Jorge
I'm not sure the NAT is the issue. Rather you don't seem to have a default-route on your switch. You have a default-gateway but this is something very different.
If you don't have it can you
1) remove "ip default-gateway 192.168.3.2"
2) add "ip route 0.0.0.0 0.0.0.0 192.168.3.2"
Jon
12-18-2008 12:16 AM
finally, I could find the solution. It was as easy as the first configuration I made:
nterface Vlan1
description LAN1
ip nat inside
interface Vlan2
description LAN2
ip nat outside
interface Vlan3
description WAN
With this configuration, I can reach from lan1 lan2 with my packets natted, and I can reach from lan1 to Wan without being natted as I expected.
Problem I had was related to an indirect route issue, but nothing regarding default-gateway as Jon thought.
By the way Jon, why ip default-gateway is something very different than ip route 0.0.0.0?
Jorge
