Martin Parry Wed, 12/17/2008 - 08:00
  • Silver, 250 points or more
You can get 4 x NM-32A (32 port Asynchronous Module) into a 3845. This would allow you to access 128 console ports. 3 x routers and 10 cards would allow console connectivity to your 300+ devices.
Hope this helps
Martin
glen.grant Wed, 12/17/2008 - 10:08
  • Purple, 4500 points or more
Expensive terminal server if you have to use a 3845 though.
Martin Parry Wed, 12/17/2008 - 11:39
yeah, pretty pricey, but he asked for replacement for the 2511's, and 3845' allow for maximum async port capacity for current router.
cisco24x7 Wed, 12/17/2008 - 12:29
Using 3845 for access server is not a smart
thing to do. Cisco 3845 is very expensive,
especially for access-server
The smart thing to do is to use Cisco 3660.
You can have up to 5x32 Async ports and one
NM module slot for Fast Ethernet. It is much
cheaper than 3845, IMHO, and more port-density.
Two 3660s will allow you to mange 300+ devices.
Martin Parry Wed, 12/17/2008 - 12:50
I can see your point, but the original request was for a current replacement for the 2511's. I have made the assumption that he will also desire the ability to be able to get support for it, but unfortunately the last day of support on the 3660's is new years eve this year. Probably won't have taken delivery and installed them before the boxes hit last day of support.
I know I wouldn't want to replace obsolete equipment in a network with other obsolete equipment.
