ACE - match on source address
Dec 17th, 2008
Hi !
I am trying to setup a LB condition based on SOURCE-ADDRESSES.
I did the following:
1) created class-map:
- class-map match-any SRC_LB
2 match source-address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
- defined policy-map
policy-map type loadbalance first-match SRC_LB_PCY
class class-default
serverfarm xxx
- and finally did:
policy-map multi-match SRC_PCY
class SRC_LB
loadbalance policy SRC_LB_PCY
BUT it says:
Error: LB action requires match vip command!
I want to match on Source-IP - not on Dst-IP.
Could you please help me ?
thx
Hans
Syed Iftekhar Ahmed Wed, 12/17/2008 - 11:14
You need a VIP to perform LB,You cannot load balance just with Src address.
You can use a combination such that Traffic hitting a particular Vip can select ServerfarmA for src add x & Serverfarm B for src add y.
Syed Iftekhar Ahmed
