DFM devices synchronisation with DCR
Dec 17th, 2008
I am using DFM ver 3.0.2 and Common Services ver 3.1.1 in LMS 3.0 bundle.
I had deleted all the devices in DCR and than added new device but in DFM devices are not synchronised with newly added DCR devices.
I tried to delete devices from DFM local database by disabling automatic device synchronisation in Auto Import Filter but didn't get any delete button enable.
I also tried to restrat InventoryCollection,TISServer and other related processes but didn't get any success.
DFM is still showing old devices list even though I enable device synchronisation in Auto Import Filter.
Is there any way to delete devices from DFM local databse through CLI.
Joe Clarke Wed, 12/17/2008 - 11:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, but you can try reinitializing the DFM databases, then re-enable DCR auto-sync to see if that corrects the problem. But before that, you really need to upgrade to DFM 3.0.4. The DFM 3.0.4 upgrade is available from Common Services > Software Center > Software Update. This update fixes two critical bugs which could explain the symptoms you're seeing.
Farrukh Haroon Wed, 12/17/2008 - 22:28
  • Red, 2250 points or more
The Delete button will show one you disable the auto-sync. I would also highly recommend the upgrade, fixed some issues for us as well.
Farrukh
