call drop Intermittently through MGCP gateway
Dec 17th, 2008
Calls are getting disconnect intermittently through MGCP gateway.
My voice gateway hardware config is as below.
two no - VWIC2-2MFT-T1/E1
Can any one help why call are getting disconnected.
Nicholas Matthews Wed, 12/17/2008 - 11:03
This offers nearly 0 information.
You'll need to be more specific about how calls drop, what you hear, what shows up on your IP phone, if it has a pattern, how long it has been happening, when it started happening, what changed, what version your gateways are on, what version CUCM you're on, what type of PSTN connection you have (CAS, PRI), error messages from CUCM or the gateway, anything.
9898nishit Thu, 12/18/2008 - 08:03
User hear beep beep...tone when calls are getting disconnected. Users are not getting any error message on phone when calls are getting disconnected. User has to redial the call.
Calls are getting disconnected intermittently. There are three E1 PRI terminated on VWIC2-2MFT-T1/E1 card. MGCP gateway's ios part no is S28NSPSK9-12403
cisco 2800 SP services. cucm version is 5.1.3c
I don't know how to check any error message related to pri line in call manager. I had observed sometime layer 2 of all three pri lines flaping, but i am not sure whether calls are getting disconnected due to layer 2 flapping or is there any problem in the config of the mgcp gateway or call manager.
Herewith i am attaching config of mgcp voice g/w and debug output.
Pl observe and help if you found anything wrong.
Nicholas Matthews Thu, 12/18/2008 - 20:19
Looks like your provider is having issues:
*Dec 18 09:11:46: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8A4C
Cause i = 0x82A9 - Temporary failure
*Dec 18 09:11:46: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8 callref = 0x0A4C
*Dec 18 09:11:46: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8A4C
Temporary failure is a non-standard disconnect cause, and means internal failure in the provider network.
ivan.garrido Tue, 11/30/2010 - 20:00
Hi Nicholas,
Actually I have the disconnect issue for inbound and outband call, I think the problem is with the  "Cause i = 0x82A9 - Temporary failure" logg, which is presents when I activated the debug isdn q931.
The topology is  PSTN-GW28XX-CCM5.1 . I talked about that and I showed the messages to Telco´s technician, but He say this´snt a problem, but I think this is not correct...
We have only one E1-PRI on gateway, and we have 51 "Temporary failure" events over a period of 36 hours including inbound and outbound calls.
Do you have any tips about root cause by the telco side or what thing they could review to find the cause.
Thanks a lot.
Ivan Garrido.
