WS-X6348-RJ-45
Dec 17th, 2008
This is regarding inline powe on WS-X6348-RJ-45 line card. I know that this card is voice upgradable.
But my query is if the voice daughter card is not present will it be displayed in the show module without serail number as below:
e-6509-a#show module 4
Mod Ports Card Type Model Serial No.
4 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL05187Q59
Mod MAC addresses Hw Fw Sw Status
4 0005.3130.6bc8 to 0005.3130.6bf7 5.0 5.4(2) 7.2(0.35) Ok
Mod Sub-Module Model Serial Hw Status
4 Inline Power Module WS-F6K-PWR 1.0 Ok
e-6509-a#
Or does above output means that the daughter card is present in the linecard.
Please suggest.
Thank you
Martin Parry Wed, 12/17/2008 - 12:57
  • Silver, 250 points or more
The WS-F6K-PWR is the daughter card. If it is showing as a sub module it should be there.
Are you having problems recorving power from the ports? Try the show power inline command.
Hope this helps
Martin
