Un-installing SDM Express
Dec 17th, 2008
I have SDM and SDM Express installed on our 871 Ethernet Router. I am familiar enough now with the router and SDM that I find that SDM Express is no longer useful. Is there documentation somewhere the will tell me what I have to do to un-install only SDM Express?
archari Mon, 12/22/2008 - 07:31
  • Cisco Employee,
Delete the *.tar files corresponding to SDM express and you should be good to go.
If you so choose, you can only run SDM from your PC (without anything stored on the router itself)
