12-17-2008 12:47 PM - edited 07-03-2021 04:54 PM
Will the AIR-AP1252AG-N-K9 N Class AP work with the 4400 WLAN controller?
12-17-2008 02:20 PM
Well the 1250 should work as long as you're on a code of 4.2 or later.
But since you are asking about a "N-K9" which I understand to be a non-fcc AP, I'm not really sure how that works. So the real question here is, what is the different inregards to registering with controllers when it comes to FCC,ETSI,Korea,etc.. configurations
12-17-2008 04:38 PM
Hi Troy,
Just to add a note to the great info from Wesley (+5 points my friend :)
The model of 1252 that you have,AIR-AP1252AG-N-K9 is the Autonomous version so it will have to be upgraded to LWAPP. You also need this minimum code version on the WLC/WCS;
Release Notes for Cisco Wireless LAN Controllers and Lightweight Access Points for Release 4.2.61.0
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn4200.html#wp302677
The following new features are available in WCS 4.2.62.0
802.11n support-The introduction of the Cisco Aironet 1250 series access point, a business-class access point based on the IEEE 802.11n draft 2.0 standard. The access point offers combined data rates of up to 600 Mbps to meet bandwidth requirements. Cisco WCS display screens include a listing for configuring, managing, and monitoring 802.11n access points and their associated wireless LAN controllers.
Have a look at these two threads that detail the upgrade of the 1252 from Autonomous to LWAPP to work with the WLC. There are some very helpful tips from Scott and Jerome;
Hope this helps!
Rob
