Quick way to change/convert Date into String?
Dec 17th, 2008
I need to pass the current Date value to a database and I need it to be in String format.
Is there a quick way of doing this?
bwalchez Tue, 12/23/2008 - 14:35
You can use the to_char function to convert a date into a string.
The DatetoTime function converts a string into a time or date.
The TimetoDate function converts a numeric time value into a string.
The GetDate function returns the current date as an integer value.
Cheng Yang Tue, 10/11/2016 - 03:41
Hi, bwalchez
Thank you for your answer. I need the DatetoTime function.
My question is where can I find these functions?
Uccx editor?
