12-17-2008 01:46 PM - edited 03-11-2019 07:27 AM
I am trying to setup a dmz and I am running into problems. I setup a windows server in the dmz thinking I would be able to ping it or at least access the fileshare. No luck. (No I won't do this in a production environment) I am new at setting up a dmz and want to get the hang of how things will work. The ASA I am working with is currently in a test environment.
The quick startup guide for the Cisco ASA appliance suggests doing the following.
DMZ = 10.30.30.0 /24
internal = 192.168.0.0 /24
global (dmz) 50 10.30.30.10-10.30.30.30 netmask 255.255.255.0
nat (inside) 50 192.168.0.0 255.255.255.0
I then put a windows machine in the DMZ and configured it with an IP of 10.30.30.50.
What I have found is I get no xlate, and I can't access the server via ping or the file share.
I have seen some references on this forum recommend
static (inside,dmz) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
Any suggestions...thanks
12-17-2008 02:39 PM
In the above case, Static is a better route to take since the packets are between the Inside and DMZ.
In the above case, any 192.168.0.0/24 traffic going to the DMZ will get translated to 192.168.0.0/24. So the DMZ network will see the inside network as 192.168.0.0/24. And if the DMZ is going to initiate the traffic to inside destined for 192.168.0.0/24, make sure the ACL applied on the DMZ permits this traffic.
Arul
*Pls rate if it helps*
12-17-2008 03:24 PM
In addition you can do a nonat exempt acl instead towards either direction if you intend to
simply NAT excempt both networks dmz and inside .
access-list nonat extended permit ip 192.168.0.0 255.255.255.0 10.30.30.0 255.255.255.0
access-list nonat extended permit ip 10.30.30.0 255.255.255.0 192.168.0.0 255.255.255.0
nat (dmz) 0 access-list nonat
Best is to reference this link to understand NAT in firewalls
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/cfgnat.html
