3560G restricting access to websites
Hi, Read your post and yes you can filter website with an ACL or access control list, you can deny your user from accessing the website IP address or you can deny the website IP access to your users.
"access-list 101 deny tcp source IP xxx.xxx.xxx.xxx destination IP xxx.xxx.xxx.xxx eq www"
You can use the any source IP command to block all host on your network. check out some links on ACL and filtering websites. HTH
