NME-AIR-WLC config fetch fails RME 4.2
Dec 17th, 2008
I am having problems with the config fetch on the NME-AIR-WLC8-K9 running I am using telnet, not ssh so the bug documented for other wlc's doesn't apply. I've checked/re-checked credentials, I can telnet fine to the device but config fetch fails (however inventory collection does work). I have installed all of the relevant device updates.
Please let me know if you have any ideas on this.
Joe Clarke Wed, 12/17/2008 - 14:01
Enable ArchiveMgmt Service debugging under RME > Admin > System Preferences > Application Loglevel Settings, repeat the job, and post the dcmaservice.log.
Joe Clarke Wed, 12/17/2008 - 17:00
This device does not appear to be supported for configuration yet. What is its sysObjectID?
Joe Clarke Wed, 12/17/2008 - 17:24
Yes, this particular WLC is not yet supported in RME 4.2. There is currently no ETA on when support will be available.
