CCM servers get PerfDisk warnings
Answered Question
Dec 17th, 2008
Here is what I get in the event log.
Unable to read the disk performance information from the system. Disk performance counters must be enabled for at least one physical disk or logical volume in order for these counters to appear. Disk performance counters can be enabled by using the Hardware Device Manager property pages. Status code returned is data DWORD 0.
Microsoft suggests that I run diskperf -y then reboot.
These warnings started as soon as I unpluged a USB external hard drive. Used that HD to do a backup of our Callmanager servers.
Correct Answer by Rob Huffman about 8 years 5 months ago
Hi Julien,
This is a pretty common problem. I got these errors once when just using a USB to load some files on CCM. Here is a link from Michael @ Cisco;
http://support.microsoft.com/default.aspx?scid=kb;en-us;296187
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 12/17/2008 - 14:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Julien,
Hope this helps!
Rob
