EIGRP neighbor drops over GRE tunnel
Answered Question
Dec 17th, 2008
I have several users working from home with an 871 router connecting to a 2811 in our main office. While most of these connections work without any issues, I have a few sites which continue to drop the EIGRP neighbor. Here is a sample of the log file
*Dec 17 06:32:48: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 172.29.1.49 (Tunnel1) is up: new adjacency
*Dec 17 06:41:58: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 172.29.1.49 (Tunnel1) is down: Interface Goodbye received
*Dec 17 06:42:03: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 172.29.1.49 (Tunnel1) is up: new adjacency
*Dec 17 06:43:41: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 172.29.1.49 (Tunnel1) is down: Interface Goodbye received
*Dec 17 06:43:46: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 172.29.1.49 (Tunnel1) is up: new adjacency
*Dec 17 06:49:30: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 172.29.1.49 (Tunnel1) is down: Interface Goodbye received
*Dec 17 06:49:33: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 10: Neighbor 172.29.1.49 (Tunnel1) is up: new adjacency
Does anyone have any thoughts as to what may be causing this issue?
Correct Answer by Richard Burts about 8 years 3 months ago
Rick
We run EIGRP over GRE/IPSec tunnels to lots of remote routers. We have seen this EIGRP neighbor instability issue, more at some locations and less at others. Frequently one side drops the neighbor relationship and sends a "goodby" to the neighbor. I assume that it has to do with packet loss dropping some of the EIGRP hello messages. We found that by increasing the EIGRP timers we reduced the frequency with which we see the problem (we are using 15 and 45 rather than the default 5 and 15).
Rick
Overall Rating: 5 (1 ratings)
ajagadee Wed, 12/17/2008 - 15:10
  • Cisco Employee,
The message "Interface Goodbye received" is due to graceful shutdown documented in CSCdr96531. The
interface goodbye is sent from the peer proactively when it takes down peers on an interface. For interface goodbye (we also have peer goodbye) it's signalled via a hello with the k-values set as invalid. On
receipt we can down the peer locally without delay.
I would suggest that you do the regular troubleshooting between the 871 and 2811 to find out why the peer clears in the first place.
Arul
*Pls rate if it helps*
Correct Answer
Richard Burts Thu, 12/18/2008 - 13:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rick
Rick
Richard Burts Fri, 12/19/2008 - 10:33
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rick
I am glad that my response was helpful. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that they will read responses that lead to a resolution of the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
