12-18-2008 12:04 AM - edited 03-06-2019 03:02 AM
act/lshut appears in 'show vlan' when I use the 'shutdown' command in vlan configuration mode. When does act/ishut appear in 'show vlan'? Command Refference says that it appears when "is shut down internally". What does mean "is shut down internally"?
12-18-2008 05:05 AM
You can shutdown a layer 2 vlan and put it into a shutdown state if for some reason you want to shut off traffic on a particular layer 2 vlan . If you go into vlan config mode and enter "state shutdown" it will kill traffic on that vlan until you bring the state back active.
02-21-2016 11:14 PM
That does not answer the question.
https://www.cisco.com/c/en/us/td/docs/ios/lanswitch/command/reference/lsw_book/lsw_s2.html
If a VLAN is shut down internally, these values appear in the Status field:
•act/ishut—VLAN status is active but shut down internally.
•sus/ishut—VLAN status is suspended but shut down internally.
So what can result in ishut?
If you go into vlan config and issue a shutdown, then it will be lshut instead of ishut
