12-18-2008 12:52 AM - edited 03-06-2019 03:02 AM
why we select baud rate 9600 in hyp terminal
Solved! Go to Solution.
12-19-2008 04:14 AM
My guess is, it might have something to do with 9600 once was often the fastest speed many RS-232 interfaces offered. Later RS-232 interfaces offered even faster speeds, but the default on Cisco was left at 9600. On the newer devices that support faster rates, pushing the rate up can considerable reduce the time for XMODEM file transfers.
12-18-2008 03:52 AM
Is this a serious question?
12-18-2008 06:10 AM
Usually that's the default speed for most Cisco console ports.
12-18-2008 07:41 PM
is there any specific reason behind that ?
12-19-2008 04:14 AM
12-19-2008 08:06 AM
Thanks atleast u giv me some satisfactory answer.
