Date and time in logging
Dec 18th, 2008
Hi all
i have two issue
1)I have a Fiber switch C3508G-XL i set date with clock set command when it become reboot it lose its date and time and go back to default date like 1-Mar-1993 like this so please help how i change date and time it remain in this switch
2) when i check its logging i.e sh logging then it show like this
Pad3-F-Switch#sh logg
Syslog logging: enabled (0 messages dropped, 10 flushes, 0 overruns)
Console logging: level debugging, 1068 messages logged
Monitor logging: level debugging, 0 messages logged
Buffer logging: level debugging, 534 messages logged
File logging: disabled
Trap logging: level debugging, 538 message lines logged
Logging to, 481 message lines logged
Log Buffer (4096 bytes):
nterface GigabitEthernet0/3, changed state to down
5w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
5w6d: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to up
5w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to up
5w6d: %LINK-3-UPDOWN: Interface GigabitEthernet0/8, changed state to down
5w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/8, changed state to down
5w6d: %LINK-3-UPDOWN: Interface GigabitEthernet0/8, changed state to up
so please help me how can i cheack logging status and its time when problem start and when its up
inayathulla1 Thu, 12/18/2008 - 01:43
Could you please paste the output of show version???
Please check the Conf reg value once.
mkumailali Thu, 12/18/2008 - 03:54
Hi sir
This is version so please
Pad3-F-Switch#sh ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 11-Jan-05 10:23 by antonino
Image text-base: 0x00003000, data-base: 0x00351B48
ROM: Bootstrap program is C3500XL boot loader
Pad3-F-Switch uptime is 6 weeks, 1 day, 16 hours, 37 minutes
System returned to ROM by reload
System restarted at 22:12:04 UTC Tue Nov 4 2008
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC11.bin"
cisco WS-C3508G-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory.
Processor board ID FAA0515K084, with hardware revision 0x01
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
8 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:05:9B:CD:16:00
Motherboard assembly number: 73-3985-07
Power supply part number: 34-0940-01
Motherboard serial number: FAA051402DM
Power supply serial number: NONE
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3508G-XL-EN
System serial number: FAA0515K084
Configuration register is 0xF
inayathulla1 Thu, 12/18/2008 - 05:29
Hi Kumail,
Thanks for the information.
Here you go the Configuration register is 0xF ...I request you to change it to 0x2102 and hopefully your problem will get resolved.
Please do it and let me know your update after that.....
mkumailali Thu, 12/18/2008 - 21:59
Hi sir
I did try config reg command to my switch but i am unable to apply this command so please can you tell me how i did use this command on switch
Joseph W. Doherty Thu, 12/18/2008 - 06:38
"Some platforms have a hardware clock that is separate from the software clock. In Cisco IOS software syntax, the hardware clock is called the "calendar." The hardware clock is a battery-powered chip that runs continuously, even if the router is powered off or rebooted. After you set the hardware clock, the software clock will be automatically set from the hardware clock when the system is restarted or when the clock read-calendar EXEC command is issued. The time specified in this command is relative to the configured time zone. "
I.e. if you don't have the hardware clock, you'll lose the date/time everytime you reboot. If you do have hardware clock, you'll need to set it. Don't know whether your device has the hardware clock.
BTW: both clocks can drift, both can be kept accurate using NTP.
PS: There's also a IOS command, clock save interval, that saves current time to NVRAM or during shutdown. This would keep the running clock from starting at the default, and would be close with a reload. Might not be supported on your device.
How time is recorded in the syslog can be adjusted.
The command you want in your configuration is:
service timestamps log datetime
There are additional options:
[ uptime | datetime [msec] [localtime] [show-timezone] [year] ]
