problems wih ASDM
Answered Question
Dec 18th, 2008
each time i install or try to run the ASDM it tells me that The procedure entry [email protected] could not be located in the dynamic link library jvm.dll. i have downloaded the jvm.dll file from java. and still it does not work.
i dont understand what am doing wrong.
Overall Rating: 5 (1 ratings)
aearley Thu, 12/18/2008 - 09:53
I found also recently that the newer versions of the Java JRE's (notably 1.6x) broke my ASDM. I went to Java's website, and dug through their download area for 'older versions' and then selectively downloaded the 1.4x and 1.5x versions. At this time I'm using 1.4.2_18, and my ASDM works fine.
Just watch out, there are some pretty nasty exploits out for the older versions of the JRE's right now.
