Private VLAN trunk
Dec 18th, 2008
  • Silver, 250 points or more
I want to configure 2 private vlans between my firewall-core-access switch.
The setup is:
firewall - trunk to coreSW - trunk to accessSW
The firewall is the L3 device for 2 new VLANs.
On the trunk between the FW and the core are multiple VLANs configured.
Access switch is C3560-E.
On the side of the Firewall - core, I only want to see my 2 primary VLANs (10,20). From my core, I want a trunk to my access switch carrying those 2 primary VLANs, and then split them up into secondary VLANs.
I checked the docs and I think if I want to do this, I need 2 physical connections from my core to my access switch because I can only configure promiscuous mode for a single VLAN.
After looking at CCO, I found that on a C4500 one can configure
switchport mode private-vlan trunk promiscuous
I think this command would sovle my problem, however, it is not (yet) implemented in the IOS on my C3560-E.
Does someone know when this will be the case, and if it indeed would solve my problem. If you would know any other solutions, I would be glad to hear them!
dario.didio Mon, 01/05/2009 - 06:52
Nobody that can help me?
