IOS Feature Sets
Dec 18th, 2008
Is there a list that shows what all the feature set codes are
ie in (C2500-JS-L)
J stands for "Enterprise" and S stands for "Plus"
Is there a list that shows all of these.
marikakis Thu, 12/18/2008 - 03:11
  • Gold, 750 points or more
This type of information is not very easily found in one place. The best I could find are the following product bulletins:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps5460/prod_bulletin09186a00801af451.html
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps5460/prod_bulletin0900aecd80281b17.html
The first bulletin includes new and older naming conventions.
Kind Regards,
M.
Jose Montes Fri, 12/19/2008 - 12:57
Hi, I hope this can help you.
I use the following summary for reference:
IOS names follow the format PPPP-FFFF-MM,
where P = platform, F = feature set, and MM = memory location (exectution area and compression).
In your example: C2500-JS-L, as you said JS, is Enterprise Plus but the L means Image will be relocated at run time
Feature Set Description
I IP
S Plus features NAT, ISL, VPDN
IS IP PLUS
J Enterprise
JS Enterprise Plus
JK8S Enterprise Plus with IPSec
D Desktop
Memory location
F Image runs in Flash
m Image runs in RAM
R Image runs in ROM
L Image will be relocated at run time
Compression
Z Image is Zip compressed
x Image is Mzip compressed
w Image is "Stac" compressed
