LMS 3.0 Cannot seem to do Device Discovery
Joe Clarke Thu, 12/18/2008 - 09:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You must make sure your Discovery filters allow the device in question. You must also make sure the device is SNMP reachable from the Campus Manager server (e.g. allowed by firewalls or ACLs).
Joe Clarke Thu, 12/18/2008 - 22:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Device Discovery filters are defined under Campus Manager > Admin > Device Discovery > Discovery Settings > IP Address Range.
Sorry, I have already tried that.. I put the whole network in the filter but the Discovery results are showing UNREACHABLE.. This is the first time I am using CWLMS. So a bit confused.. In the documents it said that if devices are Unreachable during discovery then it is due to Credential problems but I have submitted correct credentials. Still nothing is being discovered.
Joe Clarke Thu, 12/18/2008 - 23:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post your NMSROOT/campus/etc/cwsi/DeviceDiscovery.properties.
Joe Clarke Fri, 12/19/2008 - 05:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It's the same path. NMSROOT is the path into which LMS was installed. By default, this is C:\PROGRA~1\CSCOpx.
