SRST without CUCM
Answered Question
Dec 18th, 2008
Can we implement only SRST for IPP without CUCM,if we need only basic call fuction ?
Because of the budget, so if we have enough budget can we install CUCM later for more function?
Correct Answer by Rob Huffman about 8 years 7 months ago
Hi Teerapon,
Just to add a touch to the great tips from Paul and Darren (Dez :) +5 points each guys for your good work here!
SRST implies a relationship between CCM and full blown CCM, so without CCM there is no SRST. If you have two routers you can use this config for redundancy;
Here is a clip from the CME SRND Guide;
Redundant Cisco Unified CME Router
A second Cisco Unified CME router can be configured to provide call-control services if the primary Cisco Unified CME router fails. The secondary Cisco Unified CME router takes over and provides services seamlessly until the primary router becomes operational again.
When a phone registers to the primary router, it receives a configuration file from the primary router. Along with other information, the configuration file contains the IP addresses of the primary and secondary Cisco Unified CME routers. The phone uses these addresses to initiate a keepalive (KA) message to each router. The phone sends a KA message after every KA interval (30 seconds by default) to the router with which it is registered and after every two KA intervals (60 seconds by default) to the other router. The KA interval can be adjusted with the keepalive command.
If the primary router fails, a phone will not receive an acknowledgment (ACK) to its KA message to the primary router. If the phone does not get an ACK from the primary router for three consecutive KAs, it registers with the secondary Cisco Unified CME router.
During the time that the phone is registered to the secondary router, it keeps sending a KA probe to the primary router to see if it has come back up, now every 60 seconds by default or two times the normal KA interval. After the primary Cisco Unified CME router is operating normally, the phone starts receiving ACKs for its probes. After the phone receives ACKs from the primary router for three consecutive probes, it switches back to the primary router and reregisters with it. The reregistration of phones with the primary router is also called rehoming.
The physical setup for redundant Cisco Unified CME routers is as follows. The FXO line from the PSTN is split using a splitter. From the splitter, one line goes to the primary Cisco Unified CME router and the other goes to the secondary Cisco Unified CME router. When a call comes in on the FXO line, it is presented to both the primary and secondary Cisco Unified CME routers. The primary router is configured by default to answer the call immediately. The secondary Cisco Unified CME router is configured to answer the call after three rings using the voice-port ring number 3 command. If the primary router is operational, it answers the call immediately and changes the call state so that the secondary router does not try to answer it. If the primary router is unavailable and does not answer the call, the secondary router sees the new call coming in and answers after three rings.
The secondary Cisco Unified CME router should be connected in some way on the LAN, either through the same switch or through another switch that may or may not be connected to the primary Cisco Unified CME router directly. As long as both routers and the phones are connected on the LAN with the appropriate configurations in place, the phones can register to whichever router is active.
Configure primary and secondary Cisco Unified CME routers identically, with the exception that the FXO voice port from the PSTN on the secondary router should be configured to answer after more rings than the primary router, as previously explained. The ip source-address command is used on both routers to specify the IP addresses of the primary and secondary routers.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesystm.html#wp1024559
Hope this helps!
Rob
Correct Answer by dezoconnor about 8 years 7 months ago
You could try running your router as CME so that when you purchase a CUCM you can migrate your gateway to SRST.
Overall Rating: 5 (4 ratings)
paul.higgsboyo@... Thu, 12/18/2008 - 04:56
Hi, SRST needs to be configured in callmanager and the phones registered in callmanager first before SRST will work, so in short, your answer in no. Sorry.
Correct Answer
dezoconnor Thu, 12/18/2008 - 05:33
  • Silver, 250 points or more
t.sriwetchasin Thu, 12/18/2008 - 06:23
Thank very much for your advised. How about if I run one router as CME and another one for SRST ?
or However,I need CUCM to register SRST router because CME can not register SRST.
Thank you in advance.
Correct Answer
Rob Huffman Thu, 12/18/2008 - 06:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Teerapon,
Hope this helps!
Rob
dezoconnor Thu, 12/18/2008 - 06:35
Hi Teerapon, you're statement is correct. You need a CUCM to register an SRST gateway.
t.sriwetchasin Thu, 12/18/2008 - 07:51
Thanks all for your great advised. It make me clear about CUCM,CME and SRST.
The last one ... +5 for all.
Thank you very much :)
