static route not showing up
Dec 18th, 2008
Hi There, Im trying to enter a static route on a 3750 so I put in the route using the #ip route command but when i do a #show ip route static its not there , any suggestions
Sebastian Helmer Thu, 12/18/2008 - 05:01
You need to be in the config mode. the privelege excec mode# is not the correct one.
best regards
Sebastian
bruce-hunter Thu, 12/18/2008 - 06:03
Its unclear from my post but I am actually in config mode and the router accepts the command without any errors it just doesnt show up in the sh ip route
md farook Fri, 12/19/2008 - 05:57
use this following command to to see static routes.
Router#show configuration/run
charles.spaid Thu, 12/18/2008 - 06:29
The switch needs to have ip routing enabled before that statics take place. Otherwise you will have a default-gateway.
Try entering "ip routing" on the switch - that should take care of your problem.
Jon Marshall Thu, 12/18/2008 - 09:22
Bruce
In addition to Charles post about making sure you have ip routing, a static route will only be entered into the routing table if the next-hop address is reachable. So does your routing table know how to get to the next hop.
Jon
