Intermittent FXS Dial Tone
Dec 18th, 2008
Hi Guys,
I am having a problem with a VIC2-2FXS card in a 2811 router. If i plug an analogue phone in one of the FXS ports i do not get any dial tone but then if i plug it into the second FXS port i DO get a dial tone. If i try again a few secs later the dial tone is then gone from the second port and active on the first port. So basically it alternates between the two.
Some of the relevant config looks like this:
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(20)T, RELEASE SOFTWARE (fc3)
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
If i try add the network clock participate for WIC 0 which is my FXS card i get a message saying slot is empty/does not support clocking. Also tried changing the slot.
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711alaw
h323
modem passthrough nse codec g711alaw
sip
registrar server expires max 3600 min 3600
voice-port 0/0/0
cptone GB
voice-port 0/0/1
dial-peer voice 10 pots
translation-profile incoming Incoming
destination-pattern 819
incoming called-number .
fax rate disable
direct-inward-dial
port 0/0/1
Thanks in advance for your help !!!!
sebastiandm Fri, 12/19/2008 - 04:44
How would that cause dial tone to alternate between the two ports and cause the port to work sometime and other times not tho? Just out of interest.....
Nicholas Matthews Fri, 12/19/2008 - 05:53
I don't suppose it would. But it shouldn't be there. It will cause problems, even if you haven't run into it yet.
