Help with new site to site VPN
Dec 18th, 2008
I am trying to setup site to site VPN on 2 new asa's 5510 and 5505. The host is on a T1 and the remote is on Verizon static DSL. Both circuits are up and working. I am useing the GUI wizard to setup the site to site connections. When I try to ping through, the ping fails and no tunnel is opened. Here is the log file from the ping.
6 Dec 18 2008 04:36:40 302021 10.50.0.5 74.9.142.210 Teardown ICMP connection for faddr 10.50.0.5/0 gaddr 74.9.142.210/4388 laddr 74.9.142.210/4388
6 Dec 18 2008 04:37:20 302013 10.11.0.241 10.11.0.242 Built inbound TCP connection 34050 for Inside:10.11.0.241/2620 (10.11.0.241/2620) to identity:10.11.0.242/443 (10.11.0.242/443)
6 Dec 18 2008 04:37:20 725001 10.11.0.241 Starting SSL handshake with client Inside:10.11.0.241/2620 for TLSv1 session.
6 Dec 18 2008 04:37:20 725003 10.11.0.241 SSL client Inside:10.11.0.241/2620 request to resume previous session.
6 Dec 18 2008 04:37:20 725002 10.11.0.241 Device completed SSL handshake with client Inside:10.11.0.241/2620
6 Dec 18 2008 04:37:20 605005 10.11.0.241 10.11.0.242 Login permitted from 10.11.0.241/2620 to Inside:10.11.0.242/https for user "enable_15"
6 Dec 18 2008 04:37:20 302020 10.50.0.5 74.9.142.210 Built outbound ICMP connection for faddr 10.50.0.5/0 gaddr 74.9.142.210/4388 laddr 74.9.142.210/4388
6 Dec 18 2008 04:37:20 302020 74.9.140.161 74.9.142.210 Built inbound ICMP connection for faddr 74.9.140.161/0 gaddr 74.9.142.210/0 laddr 74.9.142.210/0
6 Dec 18 2008 04:37:20 302021 74.9.140.161 74.9.142.210 Teardown ICMP connection for faddr 74.9.140.161/0 gaddr 74.9.142.210/0 laddr 74.9.142.210/0
Configs in next post
thellco01 Thu, 12/18/2008 - 04:52
Site A
: Saved
ASA Version 7.2(4)18
hostname Paetec
domain-name Paetec.thelandlcompany.com
enable password nRkrK2UDMhbxbMqH encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface Ethernet0/0
nameif Outside
security-level 0
ip address 74.9.142.210 255.255.255.240
interface Ethernet0/1
nameif Inside
security-level 100
ip address 10.11.0.242 255.255.0.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa724-18-k8.bin
ftp mode passive
dns server-group DefaultDNS
access-list Inside_nat0_outbound extended permit ip 10.11.0.0 255.255.0.0 10.50.0.0 255.255.0.0
access-list Outside_1_cryptomap extended permit ip 10.11.0.0 255.255.0.0 10.50.0.0 255.255.0.0
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu Inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-52450.bin
no asdm history enable
arp timeout 14400
global (Outside) 101 interface
nat (Inside) 0 access-list Inside_nat0_outbound
nat (Inside) 101 0.0.0.0 0.0.0.0
nat (management) 101 0.0.0.0 0.0.0.0
no threat-detection statistics tcp-intercept
route Outside 0.0.0.0 0.0.0.0 74.9.142.209 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
http server enable
http 192.168.1.0 255.255.255.0 management
http 10.11.0.0 255.255.0.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set peer 162.83.93.74
crypto map Outside_map 1 set transform-set ESP-3DES-SHA
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 10.11.0.0 255.255.0.0 Inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
tunnel-group 162.83.93.74 type ipsec-l2l
tunnel-group 162.83.93.74 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:c280c048fbd9093b13cb15fcbe557316
: end
Site B
: Saved
ASA Version 7.2(4)
hostname Culpeper
domain-name Culpeper.thelandlcompany.com
passwd Lowik8FFent8v7l9 encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.50.0.5 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 162.83.93.74 255.255.255.0
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
ip address 10.32.0.10 255.255.0.0
switchport access vlan 2
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
access-list inside_nat0_outbound extended permit ip 10.50.0.0 255.255.0.0 10.11.0.0 255.255.0.0
access-list outside_1_cryptomap extended permit ip 10.50.0.0 255.255.0.0 10.11.0.0 255.255.0.0
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool Cul 10.50.0.10-10.50.0.30 mask 255.255.0.0
icmp deny any outside
asdm image disk0:/asdm-524.bin
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 162.83.93.1 1
http server enable
http 10.11.0.0 255.255.0.0 dmz
http 10.32.0.0 255.255.0.0 dmz
http 10.50.0.0 255.255.0.0 inside
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 74.9.142.210
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
encryption 3des
hash sha
group 2
lifetime 86400
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
telnet 10.50.0.0 255.255.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
tunnel-group 74.9.142.210 type ipsec-l2l
tunnel-group 74.9.142.210 ipsec-attributes
pre-shared-key *
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
Cryptochecksum:2005003b9cea63c18a605e291f62f63f
: end
Thanks in advance for any help
Richard Burts Mon, 12/22/2008 - 11:56
Justin
I have looked at what you posted and I believe that there is a small problem in your config which should be addressed. The ASA5505 host B in its crypto map does a set pfs which the ASA5510 host A does not do. I suggest that you get the crypto maps to be mirror images of each other. (either remove the set pfs from B or add set pfs to A).
But I believe that the biggest problem is in how you are trying to start the tunnel. In the output in the first post you are attempting to ping the remote to start the tunnel. But the ping is sourced from the outside interface of the ASA. This is shown in this output:
where the local address is clearly 74.9.142.210 which is the outside interface address. Since the crypto map only matches traffic with source address in 10.11.x.x/16 this ping does not start the tunnel. I suggest that either you get the ping sourced from the inside interface address or modify the crypto map access list to include traffic to the remote sourced from the outside address.
Rick
