CUE, SIP trunk and Transcoder
Dec 18th, 2008
Hi all,
I have a problem with my Cisco Unity Express.
It works great when I call it from internal calls, but I can't call it from outside.
We use a sip trunk to made calls from and to outside.
So if I try to made a call to a users with a ip phone, its works great.
But it doesn't work when I try to join the directory number of the cti port corresponding to the CUE.
I think it's a problem of transcoding, because the trunk sip use g729 and cue g711...
But I configured a transcoder, and it works for remote site which call in g729, but it doesn't work with ouside calls.
Is someone have a idea?
j.gimbert Fri, 12/19/2008 - 01:01
I forgot to say that I use a CCM v5.1 and a VG 2851 with CUE 3.0, not a CME...
I try on the VG
voice service voip
allow sip-to-sip
but it doesn't work.
Nicholas Matthews Sat, 12/20/2008 - 05:36
  • Red, 2250 points or more
Try making it so that the region to region codec for an outside call to CUE uses G711. You may need to create a new region for CUE to do this.
jerome.gimbert Tue, 01/06/2009 - 04:46
Ok,I created a new region for the CUE. I will try to play with the region to region codec.
jerome.gimbert Tue, 01/06/2009 - 04:57
I tried and it doesn't work.
The Sip Trunk is on a region and the CUE is on another one.
I tried to configure the transcoder on the same device pool than the sip trunk and than the CUE, without result.
I tried to change the codec between sip trunk region and CUE region, without result.
I really don't know how to do ...
